no power to the injectors
I have no power to my injectors. '88 L98 in a '90 t/a. I haven't been able to get it started an I think this could be the problem. Both fuses in the block are good. If youhave any ideas please share them!!
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
when you say good fuses in the block, do you mean that they are also powered with 12v switched ignition the way they should be? run a jumper in the engine compt. from the 12v battery positive to the injector feed wires(which become black and pink in the engine compt. harness) and see if it will fire off. is the ecm doing its part as far as the ground portion of the circuit? check that with a powered test light while cranking-it should flash when you are on the correct injector terminal. all of the above work should only be attempted if you are aware what a mis-applied 12v battery current can do to ruin your day and perhaps even longer than that. later
Thanks for the reply, but I got the problem fixed a month or so ago. There was a discrepancy between the car's dashboard harness and the engine harness. I just had to do some custom wiring to get it to work.
yeah i was so dang excited to help that the reading skill starts slippin and my vision starts cutting off the last sentence on the page and before ya know it, theres blonde hair where there was none. go figger. is the wiring that you did kustom with a "k" or custom with a "c"?
mdtoren
Aug 16, 2015 05:45 PM
