Ecm?
Old Apr 15, 2003 | 08:48 PM
86TATpi's Avatar
Ecm?
I haven't gotten an answer hoping this was something else, so I'm kind of thinking that the ECM or prom may be shot. Sometimes when I'm driving the SES light flickers. When it stays on it runs bad. If I smack the dash by the computer the light turns off and it runs better... until I stop then it either stalls or idles really low. It won't pull up any codes, it acts like nothing happened. Also when the light does stay on the fan turns on with the light. I'm sorry if it's not enough information. If anyone needs anymore I'll try my best to put it down.
1986 Trans Am 5.0 TPI stock for now
Old Apr 16, 2003 | 08:35 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
My first thoughts lead towards poor connections or bad wiring. Check for tight, clean connections. Look for chafed or torn wires. Check and clean grounds. It may get tedious, but do it anyway.
It sounds intermitent and I would guess a wiring or electrical problem. Good luck. If you have anymore info that you think is useful, put it up.
Old Apr 18, 2003 | 06:11 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Ecm?
Try another ecm if it's a 1227165, they've been known to do things like that. 2nd guess is the MAF.
Maybe Need4speed has an answer with better information.
Old Apr 19, 2003 | 12:04 PM
86TATpi's Avatar
The ECM number was 1227165. When putting another ECM into the car does it matter which one you put in? As long as it has the original prom?
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
