injectors won't fire
Old May 7, 2003 | 02:58 PM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
This is my problem:
My injectors are brand new accel injectors, I had just put my miniram intake. The car was running good before I took off the miniram. I had to replace the gasket, and after I got it back together the car would just crank but not start. So I checked wiring, the two fuses in the box, replace my ignition module, checked the fuse next to my battery. I think that is everything I did, I don't really know how to check my ecm to see if it is alright or not. Right now I have an ecm on order and am waiting for it. I don't know what else to do, any help from anyone would be great!
thanks
jason
Old May 13, 2003 | 02:49 PM
primo's Avatar
Jason,
If you removed the distributor to install your new intake, it is posible that is out of synch or a 180 DEG out.
Also check if you have reference pulses from your distributor, check your distributor connections.
Good luck,
Old May 17, 2003 | 08:58 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
I don't suspect the injectors aren't firing. Here's an easy way to check. Unplug one of the injector clips and put a test light probe into one of the terminals. Ground the other end of the test light. Turn the engine over. With each revolution the test light should dim a bit. If it does, then the injectors are recieving the right information from the ECM and it's time to check that distributor
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 21, 2015 07:20 PM
justin57
Aug 20, 2015 07:05 PM
