ECM fuse problem HELP!!!
Old Jul 17, 2003 | 12:17 AM
rscamaro305's Avatar
hey guys i posted this in electronics and i got little help hopefully you guys can relate to this and help me out I was driving home on my lunch break to get some food and while getting on the freeway the car stopped getting fuel and died then wouldn't start again. I got it to my favorite autoshop on a hook and we found it blew a ECM fuse. We tried to figure out why by looking at wires and all looked good. We plugged in a new fuse and the thing was ready to rock and roll again. Then i drove home and it blew the fuse again when i reved it past 3000 so i put in another fuse and nursed it back home. So do you guys have any ideas why it is drawing over 10 amps? I'm fairly sure it is a short somewhere. Do you guys have any idea where, is this a common problem? thanks a lot for any help.
Old Jul 23, 2003 | 07:54 AM
Albert Capecci's Avatar
Maybe the wiring harness near the engine is rubbed through, try wiggling wires. I found a sheet metal screw that was going through a bracket at the rear of the engine by the firewall sticking into the large engine harness on an 88 TPI , wasn't shorting all the time.
Old Aug 10, 2003 | 12:11 AM
Krag's Avatar
Car: 1987 Monte Carlo SS
Engine: 406 w/TPI
Transmission: 6-speed
Same thing happened to me... my harness was rubbing and unknown to me it was making contact with a sharp object, it drove me NUTZ!!! It would blow the ECM fuse, I would replace it and it would idle all day but as soon as I started driving and the rpms went past 3000 it would blow the fuse again!!!
Check out the harness and run your hand under it to make sure it's not against a sharp or hot motor part.
Good luck!
Old Aug 10, 2003 | 12:19 AM
thanks for the help, i'll work on it as soon as i get better. I hate being broken.
Old Aug 12, 2003 | 01:48 AM
Krag's Avatar
Engine: 406 w/TPI
No problem... I had to laugh that day.. I had blown fuses ALL over the floor ...I finally put in a 30 amp circuit breaker till I found the problem! (I was going broke buying fuses!!!)
Hope you get well soon... AND your ride too!
Old Aug 12, 2003 | 08:24 PM
those electrical problems can drive you crazy. Especially when you cant fix them. With any luck i'll be out of the sling in a week and ready to rock and roll. They said in motorcycle safety school that no one sees you when you're on a bike and getting in an accident is not a matter of "if" it's a matter of when. And it had to be the shifting hand too, go figure. Hopefully the beast will be running again soon.
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
GTAman
Mar 15, 2019 11:40 AM
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 13, 2015 12:59 PM
