Got my ALDL cable.. have a ton of questoins
Old Aug 19, 2003 | 03:06 PM
bigals87z28's Avatar
Car: Check The Sig
Please help me out. I have a whole CD full of scanning software and a new aldl cable and im ready to see what the computer is reading! I read one of the warnings and it went a little something like this...
!!!!!!!!!!!!!!!!!!!!!!!!!!!!! >>> C A U T I O N <<< !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
! NEVER RUN ENGINE IF SES LIGHT PULSES AND DISPLAY DIAGNOSE CODE !
! ( if A & B pins are short circuit and ignition key is ON ) !
! IT CAN BE DANGEROUS FOR YOUR ECM AND CAN DESTROY YOUR ECM. ( ca 150$ !
! Dont hook up interface while engine is running, or if interface is damaged !
! or broken etc. !
Dose that mean i cant scan the ECM while the car is on? I dont want to see codes, i wana see sensor information!!! what is the deal!! someone help with this? Is it BS?
Also, on the CD i got, i have a lot of software put on here.
Some of the programs that are on the CD are Autotap, WinALDL, Craig Motes, Diacom, tunner cat, datamaster, along with 4-5 other programs. Can someone fill me on what i need to do to get started? It also said that it wont work with 2000, NT or Xp. I understand that, so i have no problem. I plan on getting a used laptop for cheap so i can use it for scanning, and maybe ill use it for school... who knows? Thanks for the help guys.
Old Aug 19, 2003 | 10:58 PM
Car: Check The Sig
anyone!! anyone at all!!! helllllo! please! i have a lap top... sort of...
Im trying to get my lap top to start up win 3.1. I got it to do it last time, i just dont know what happend. I need some serious nerds to come help me out. Might take it to work and have somene look at it.
Old Aug 22, 2003 | 12:51 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Lap Top
I recommend using Win95 instead, surely someone has a win95 cd-rom lying around, or an upgrade.
Old Aug 25, 2003 | 07:01 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Got my ALDL cable.. have a ton of questoins
[i]
! or broken etc. !
[/B]
Don't start the car if you've grounded pins a & b.
Hook up your aldl cable before you've started the car.
Old Sep 3, 2003 | 11:11 PM
Car: Check The Sig
Re: Re: Got my ALDL cable.. have a ton of questoins
wait... do i dont need to ground a & b when im running winaldl? that only would run the code scanning right? Ok, well i did that and i hope everything is fine... car still starts.
Old Sep 4, 2003 | 05:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
If you have the cable with an OBDI connector you just plug it in. If you have the cable that gets spliced into the wiring in back of the car's OBDI then you do nothing.
xodus2002
Jul 17, 2020 09:08 AM
loud91rs
Oct 5, 2015 10:05 PM
WejaZ28
Oct 3, 2015 07:38 PM
3.8TransAM
Oct 1, 2015 07:47 PM
greenyone
Sep 8, 2015 08:41 PM
