DIY ECM Hybrid - Questions Progress
Old Sep 8, 2003 | 01:24 PM
jimbo69's Avatar
Car: 91 Firebird
Engine: 305 tbi - 122k
Transmission: 5 speed
I have a couple of questions E3 ECM
What outputs do you get from the ~CRANK analog signal, does it tell crank position, if not why is it analog? I know that it tells the computer that you are cranking over the motor.
What is PSPS?
Why IS ~ACREQ signal analog?
Is PN park nutrual? Why is it analog? is this also used for the clutch on manual transmissions?
See pic for schematic
Old Sep 8, 2003 | 10:54 PM
Ken73's Avatar
Car: 82 Corvette
Engine: 350 CrossFire
PSPS = Power Steering Pressure Sensor. I believe it was used on V6 applications where power steering drag had more of an effect (Although the application may vary.)
~CRANK is grounded when you're cranking the motor over. Not quite sure what exactly it does for the ECM though. (Probably voltage correction for pulse width?)
~ACREQ is A/C request - tells the ECM when your compressor is kicked on, so it can add fuel if need be to keep the idle up.
PN is Park/Neutral, just as you suspected. Tells the ECM when it's in gear, basically.
Old Sep 8, 2003 | 10:59 PM
jimbo69's Avatar
Car: 91 Firebird
Thanks,
Good don't need PSPS I only have 7 usable a/d lines and if crank just goes to ground then that is fine also, just use standard port for it. A/C compressor should be on/off also or I don't need to use it at all.
I'll have more questions later on... But am working on the schematic.
Old Sep 9, 2003 | 12:16 AM
Morley's Avatar
The crank is used (I believe) for crank "counts" as in the ref pulses from the dist when first cranking, it has to know how many pulses during cranking to get the added fuel for cranking (starting) in there.
The AC request should be tied (in the ECM) to the IAC and fan #2 relay. It adds steps to the IAC during idle with AC running to keep the engine alive (also engages/disengages compressor at different engine loads) and grounds the #2 fan relay to turn the fan on.
Old Sep 9, 2003 | 12:48 AM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
Crank, is positive signal, that if it's used has a fuse in the fuse box, not all C3 ECMs used it, most did however. It s tied to the ignition switch, and only goes active for the period that the engine is cranking (starter engaged)
I do not know it's purpose in refernce to the ECM, I can only speculate and think that it may be for a start retard, or cold start injector use, or something along those lines.
Old Sep 9, 2003 | 01:51 AM
Morley's Avatar
Cold start injector is independant of the ECM, it uses a thermo-time switch to activate it.
Old Sep 9, 2003 | 02:14 AM
jimbo69's Avatar
Car: 91 Firebird
From looking at the code, it looks at the crank signal to start the injectors in a tbi system and initiates starting procedure. From there I believe it looks at the distributer signal to see if the engine is running and adjusts IAC. Only went through the code once so far. 150 pages of ROM takes a while. Seems to be some fluff in there also. The megasquirt code turns on the injectors full while cranking.
Something I haven't gotten to yet is the spark, is there a seperate controller that the ECM talks to or does it do the spark also. Looking at my manual it looks like the computer communicates with the spark system.
I printed out Megasqirts assembly code, it's a lot easier to follow at only 50 pages or so. But does not do spark.
Here's the IAC schematic. Page 1 and 2
Old Sep 9, 2003 | 02:16 AM
jimbo69's Avatar
Car: 91 Firebird
Oops
I'm assuming that the IAC is pwm controlled or is just stepped.
Old Nov 18, 2003 | 06:48 AM
jimbo69's Avatar
Car: 91 Firebird
Update
Well I've been working on another project that makes money. But I have the interface for the display and IO expansion working. I'm going to play with the motor drivers next to see if they can drive the injectors ok, they are only rated at 2 amps 12v, may need to get some bigger drivers or have the computer fan cooled. But they do have inductance feedback cancellation built into the chips.
Hopefully this week I will be able to show some picks of the injectors spraying
Old Nov 18, 2003 | 09:27 AM
TORC's Avatar
I believe the crank signal is also used to activate the fuel pump relay until oil pressure can build up to close the oil pressure switch..... I think.
Old Nov 18, 2003 | 06:23 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Sorry guys, but this post looks MUCH better on the DFI/ECM Board. Now you can get RBob to help too.
Old Nov 18, 2003 | 09:02 PM
JPrevost's Avatar
Car: 91 Red Sled
The cranking in most TBI applications have a seperate desired cranking afr vs temp. That's what the cranking input is used for .
Old Nov 18, 2003 | 09:57 PM
jimbo69's Avatar
Car: 91 Firebird
Here's what I've been playing with utilizing the display, and suggestions would be helpful
sailtexas186548
Aug 26, 2015 03:32 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Catcher55
Aug 15, 2015 07:08 PM
