Holley Stealth ram.too tall???????????
Old Sep 17, 2003 | 01:40 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Right guys,
The holley stealth ram complete set up has now been decided on to top my new ZZ4 in my 85 transam but then...Ive read it may not fit under the stock bonnet.
Help me out guys,does it fit or not??
PM
Old Sep 17, 2003 | 04:01 PM
jeffsbluez's Avatar
Car: 91 z28
Yes and no! If you have a stock "rs" type hood it will fit. Do a search for "stealth ram and hood" That should help you out.
Old Sep 25, 2003 | 12:00 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
I would be interested in seeing an "rs" hood on a trans am. . .
I have my HSR installed under a base model firebird hood (on a trans am . . . if it matters). It is, at best, VERY close. My hood has some of the bracing trimmed back to clear the front lip of the square part of the throttle body.
I use the screw-type hose clamps to hold a rubber connector to the TB. If i leave the screw part on top, it WILL contact the outer hood skin. I've been using modeling clay to determine clearances and right now i estimate 1/4" at the closest point of contact.
Hope that helps and puts everything in perspective.
Old Oct 5, 2003 | 08:42 PM
trigger GTA's Avatar
Car: 92 TA vert
slickrock55
you would hot happen to have a pic of what you need to trim out of the hood do you
Old Oct 5, 2003 | 10:56 PM
Car: 82 Trans am
Heres a pic i borrowed from JMatlock88 and drew on:
I only cut what you see in green, he cut a whole lot more, do a search for his post on this, tons of good info.
Old Oct 5, 2003 | 11:28 PM
Car: 82 Trans am
I became less lazy and looked this up:
https://www.thirdgen.org/techbb2/sho...ht=stealth+ram
Old Oct 6, 2003 | 11:06 PM
89transam's Avatar
Before you go and bust out the heavy duty cutter try tin snips. They work awesome and will not damage your hood if you slip, I think that JM matlock pic should be banned got all sorts of crazy ideas in my head and probobly other ppls too. That metal is like butter, there is no need for that hardcore of a tool.
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
thekurlyone
Sep 30, 2015 12:54 PM
dusterbd
Sep 29, 2015 08:40 AM
R3500
Sep 8, 2015 10:12 PM
