Voltage to knock sensor @ ~2.8V, bad ECM?
Old Oct 7, 2003 | 04:00 PM
377Z's Avatar
Car: 2007 Volvo S60R, 2005 Audi A4
Engine: 300HP 2.5L I5, 200HP 2.0L I4
Transmission: TF-80SC, Getrag 6 speed
Axle/Gears: 3.33:1, 3.54:1
Checked the voltage at the knock sensor circuit with car off, ignition on. Measures around 2.8 volts, service manual says it should be 4-6V. Also, if I tap the block with a hammer like this, there is no change in voltage--shouldn't there be even though the car is not running (knock sensor is just a resistor variable w.r.t vibration right)? I've been getting a code 43.
Car is a stock 91 305TPI T/A.
TIA
Old Oct 22, 2003 | 05:34 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
I don't think that you can measure the voltage difference with a voltmeter. The Knock sensor is a Piezo device, and reacts VERY fast. You will have to look at it with an o-scope. Try to disconnect the leads to the sensor. IF the sensor is bad, it may drag the ECM voltage down. Best I can do for you, good luck!!
89GTAOz
May 16, 2020 09:31 AM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Jae992
Aug 27, 2015 09:07 AM
