ECM and th700->t5 conversion problem
Old Nov 23, 2003 | 02:12 AM
szymon86iroc
Guest
Posts: n/a
After T5 conversion I noticed stalling while gear changing 3->2, 2->1. There's also troublecode about park/neutral switch. I made a custom switch on this circuit but it doesn't help switching it manually. Do I need to change ECM or PROM to make it work with manual tranny? It's '88 TPI 5.0
Old Nov 24, 2003 | 01:03 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ECM and th700->t5 conversion problem
Typically can get away without changing the MEMCAL on an auto to stick swap. In your case it seems like it would be best to get the proper MEMCAL or burn the correct PROM.
On a stick the pk/neut line is left open. On a scan tool this will show up as being in drive. Getting an error code on it sounds strange. The VSS operational?
RBob.
Old Nov 28, 2003 | 10:56 PM
stevedave454's Avatar
Car: 91 S10
im doing a 350 tpi swap into an s-10.. my tpi unit is an 88 mas air and the chip is for an auto, but i will be using 5 speed... so basically will i be running into the same problem?
Old Nov 29, 2003 | 09:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Had a thought, check the IAC for proper operation. A sticking or non-operational IAC would cause stalling.
RBob.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
2012sergen11
Oct 13, 2015 07:38 PM
customblackbird
Oct 1, 2015 04:30 PM
