is this the same ecm?
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
ok guys i have a ecm here out of a 92 v6 3.1. it has a blue chip in it it looks to be the same as a v8 tpi ecm. i am planning on getting a new chip for it and running my lt1 intake swap off it will this ecm work? are the 92 sd v6 and v8 ecm the same? any help is much appreciated. thanks guys
Car: check
Engine: check
Transmission: check
Re: is this the same ecm?
Only difference will be the MEMCAL. Will need to get one for the V8 car. The MEMCAL is the unit with the blue cover, push down the clips at each end and it will pop out.
RBob.
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
is the memcal different or just the chip? im goin to have a chip burned for it soon. will i still need a new memcal?
Car: check
Engine: check
Transmission: check
RBob.
efiguy
Sep 27, 2015 01:30 PM
