when switching to the 749 ECM....
Old Dec 29, 2003 | 09:56 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
... im not finding anything about changing the air temp sensor..
wouldnt you have to change the sensor since boosed apps can have some really hot intake air? or does the stock one have enough range already?
Old Dec 29, 2003 | 01:37 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: when switching to the 749 ECM....
Stock one will be fine.
RBob.
Old Dec 30, 2003 | 09:54 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
To some degree it matters where you mount it.
If right at the compressor discharge, you would run at the upper end of it's limits. If you mount it in the plenum, you'll be OK.
None intercoolered with the MAT in the plenum, I think the hottest I recall has been just over 200dF.
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
tglennon11
Sep 23, 2015 05:30 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
