HSR Wiring
Old Jan 4, 2004 | 01:55 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
HSR Wiring
Im preparing my 85 Transam TPI for my forthcoming ZZ4 and HSR/Commander 950.
Am I correct in assuming that none of the wiring which currently goes into the ECU, will be wanted with this conversion?
Also ive noticed that when i diconnected the ECU there were three connector blocks with various amounts of cables which seemed to exit the ECU wiring loom and disappeared somewhere under the dash.Any ideas what these could be and wether they now will not be needed.I
I'd previously removed all emissions so i know there must be some wiring left over from that,plus i'm converting from 700R4 to T56,so I know there must be some wiring connected to this.
Appreciate some help if poss
Cheers
PM
Old Jan 6, 2004 | 12:55 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
TCC & fuel pump circuits go through there, plus few others, I can't remember them all now, It's been a few years since I did mine. Everything else is not used.
Old Jan 7, 2004 | 01:06 AM
powermite's Avatar
Car: Transam
Im swapping to manual now so i havent got TCC ans yes i did realise the fuel pump but thats easy enough to rewire.
PM
trevor1010
Aug 26, 2015 02:41 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
trevor1010
Aug 24, 2015 08:34 PM
trevor1010
Aug 24, 2015 11:29 AM
355tpipickup
Aug 22, 2015 06:06 PM
