93 GMC, TBI, Chip Burning, Tuning
Old Feb 14, 2004 | 10:19 PM
1993GMCPU's Avatar
Car: TBI CHEVY, TPI 5.0 HO
Engine: 5.7 FIRST hp SMALL BLOCK, BIG BLOCKS!
TBI ECU is listed as: Service # 16168625 BBMW BBWK330491987, well this was a 4.3 z 1/2 ton pickup, but it's now a 5.7, 350 bored with HYP Federal Mogul H345NP40 pistons, ARP rod bolts resized rods, balanced etc. Comp 212-218, 444 lift cam, transmission 4L60E rear end 3:42s wanting to go to 3.73 later depending on how things go.
I had TBI modify TBI and they put in, Yellow/Brown, 68 Flow Matched injectors and made a chip, but both stock chip, PROM, based of VIN except for 5.7 and their custom chip well just don't seem to cut it for me.
I seen Tunercat, winALDL and I wondered how hard it is to burn a chip and is it possible to get a little more option on cams because, in my opinion, Edelbrock TBI cam etc, just are not enough for what I wanted out of motor, let alone if we go to a 383 next year, depending on if we can learn this and a TBI can use other options when GMC specs are changed. We were going to use Pro Torkers 67 cc with 2.02-1.60 valves, but may be stuck using, for now, 1.94 1.5 SR Pro Heads with Fel Pro 1094 gasket and shaved .020 to up compression some as well to help, I hope keep compression and vaccum up. MAP and TBI seem to not like it if vaccum drops and I am assuming ECM etc thinks motor is under load, bummer. ANY suggestions on how to do this and where to start? Please?:hail:
Do you need a scanner or other tools as I just use a paper clip to pull codes when I had to trace code 42, bummer was a short in EST, boy what a pain that was. I have access to computers though and figured after it cost so much for custom chips and 50 dollars there after to change chip they did wrong, well I need to learn or go to a Holley. CFM on TBI is suppose to be around 590 and T.C. claimed Injector spacer would help and selling TBI Edelbrock Manifold 3701, looking at options or single plane.
MustangBeater20
Oct 29, 2022 09:20 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
Bryan F
Aug 18, 2015 02:28 PM
Exxon Limited
Aug 9, 2015 08:13 PM
