gen7-just outof box??'s
Old Feb 15, 2004 | 07:45 PM
BANDITSBC's Avatar
Car: 90 gta
Engine: 5.slow turbo
Transmission: tremec tko
ok guys thanks for looking, here's the deal, i just got the gen 7 brand new, i like doing my homework before getting involved with everything,
1st?- it looks like my 77022 didn't come with a manifold temp sensor or any others for that matter, i'm trying to get hold of the people i got it from, but is there a mts i can get from auto parts place to use? same for the oxygen sensor, it uses a 4 wire is it the same as gm's 4 wire? and will it fit into the oem o2 fitting?
2nd?- did u need anything else when hooking it up? i work in a dealership so odds and ends won't be a problem,
thanks
jim
Old Feb 15, 2004 | 09:42 PM
biggtime's Avatar
It uses GM sensors except the 02. Get that from accel. you will also need to fab up a manifod surface temp bracket. If you bought your unit as a kit complete with harness it should have came with all of the sensors except a IAC. I have bought 4 so far and they all came with everything. Check with the people you purchased it from.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
