Can I test my Accel system using a stock ECM?
Old Mar 6, 2004 | 11:02 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
My fuel pump won't turn on and I am tired of checking wiring, can I just plug in a 89 MAF ecm into the harness to see if the fuel pump will prime without totaly screwing up the system? Car was TBI converted to accel gen 6.
Old Mar 7, 2004 | 09:36 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Can I test my Accel system using a stock ECM?
I would not attempt it. I would be surprised if the harnesses were the same. Did the fuel pump ever work with the Accel system?
Should be able to troubleshoot it in a different manner.
RBob.
Old Mar 7, 2004 | 09:48 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Plugs right in, now I just need to find the custom relay that I took out to try and find more info on, I know it is around here somewhere......
Old Mar 7, 2004 | 01:19 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Never mind, finally found the fuel pump fuse and it was toast, there was another fuse out in the open near the dist block and I thought that was it but after tracking the wires I found the right one. Now to figure out why I am getting no spark.
Old Mar 7, 2004 | 02:36 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Good news at that. I am not familiar with this Accel system you are running. It sounds like it is a replacement for the factory ECM, and uses the factory harness. Am I understanding correctly?
TIA, RBob.
Old Mar 7, 2004 | 03:39 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Yes is looks to be a direct replacement for the GM ECM since it plugs right in. As with most custom installations if you don't do it yourself you sometimes have a hard time figuring out how it was installed. Not sure what else needed to be done to allow use of MP instead of TBI. I'll have to go back and check if I might have dislodged a wire or something since I am now getting no spark.
tazs2000
Jul 15, 2017 08:44 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Jae992
Aug 27, 2015 09:07 AM
marcusaw
Aug 10, 2015 08:13 AM
