A/C control
Old Mar 14, 2004 | 01:09 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
A/C control
Does anyone know if the 730 ECM is capable of controlling the A/C compressor relay as the 727 ECM is. If so which pin is for the control to the relay.
Old Mar 14, 2004 | 01:32 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: A/C control
$8D mask as such the Corvette uses? D3 is A/C request, F3 is A/C relay control.
RBob.
Old Mar 14, 2004 | 05:46 PM
eric305TPI's Avatar
Yes I'm refering to the $8D mask.
Old Mar 14, 2004 | 06:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The pins I posted above are for the '730 ECM. May or may not need to tweak the calibration parameters to have the A/C operate. All depends upon the BCC used. Don't know of any other reason it won't work (besides a little re-wiring).
RBob.
Old Mar 14, 2004 | 09:36 PM
eric305TPI's Avatar
Currently the A/C on input is on pin C9. Does this need to be moved to D3 or does the request circuit need to be added.
Old Mar 15, 2004 | 08:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That is a status input. It lets the ECM know that the A/C compressor is active. Allows the ECM to control the idle & fans relative to the A/C compressor being engaged.
RBob.
junior419
Apr 7, 2025 11:35 AM
Nervous2
Oct 8, 2015 10:53 PM
RacerM
Sep 28, 2015 04:25 PM
Mdenz3
Sep 17, 2015 08:36 AM
85Special
Sep 3, 2015 04:21 PM
