info on ecm wanted
Old Apr 6, 2004 | 04:31 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
info on ecm wanted
ecm info needed
what is the dif from the 1228063, 1228746 and 1227747 ecms
is one better than the other. are the wiring harnesses the same is one more tuner friendly.
what are the pros and cons of each
Old Apr 7, 2004 | 08:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: info on ecm wanted
Originally posted by c4boom
ecm info needed
They are all plug compatable. The '8063 & '8746 also support an IAT and CCP which the '747 does not.
(also see my response on the diy prom board fro additional info).
RBob.
Old Apr 7, 2004 | 07:06 PM
c4boom's Avatar
Engine: l98 and lo5
is there a way that you can mirge the two threads so there will be only one and that one will be in this forum
Old Apr 7, 2004 | 07:44 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Short of a cut&paste I don't believe so.
RBob.
Old Apr 8, 2004 | 02:24 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
ecm info needed
I can fill in for the 8063. So far from what ive seen the 8063 is pretty much the same as teh 8746. Most of the code present in the 8063 is also present in the 8746. There are some notable differences, though. For one, the $4D offers the option to use the IAT in place of the cool temp for some of the lookups, most notably the cool comp. spark advance table. It also has a full temperature range BPW correction table for the IAT instead of jsut a couple values at higher temps. Another little interesting feature is the fact that it can use the map/baro for the main VE lookup instead of the SD MAP to adjust for altitude. It also does corrections to the WOT AFR depending on what the tps is. On an important note, the 8063 will not do closed loop idle unless in gear. Out of gear, it jsut sort of idles wherever and only makes adjsutment if the speed is too low or too high. Theres some other wierd little things in there that dont do anything but other then that its pretty much the same deal.
Bottom line...
The IAT stuff is good. Finally some ability to adjust the fuel and spark by the IAT, even if it is pretty feeble. Otherwise the tune is less then desirable and it left alot to be desired even on the stock L03. If I had to use one in stock form in a car application Id use the 8746 over the 8063
specialized
Jun 18, 2022 09:26 AM
Jae992
Aug 27, 2015 09:07 AM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
gta power
Aug 13, 2015 06:15 AM
Poncho92
Aug 7, 2015 08:15 PM
