benefits of a dual ignition system car?
Old Apr 8, 2004 | 07:32 PM
Trux's Avatar
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
Hey guys,
was wondering if there were any benefits from using to seperate ignition and DFI systems on an engine. Does it make sense?
Tricking a computer to think it is on a 4 cylinder and just have 2 computers, one for each bank.
What do you think? Is it just a waste of money?
thanks for your input
Old Apr 8, 2004 | 07:50 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Alot more work then I see as being necessary.
If you alternate firing each bank of cylinders to every other crank revolution, and make it a true bank to bank system you can get an extra 5% effective Duty Cycle out of the injectors.
But, if you're using large injectors that might work against you.
Old Apr 8, 2004 | 09:05 PM
Trux's Avatar
Transmission: t-56
oh
I was thinking there would be some benefit but not really sure what it would be.
I am planning a twin turbo engine and was thinking of having a seperate intake for each bank. I think would might run into problems with unequal boost on each bank though. I am thinking of using somehting around 50 lb injectors, although I really want to try using two injectors per a cylinder. maybe a 24 lb anf switch to the larger injectors for racing. I was also thinking of using two systems for this setup, what do you think?
Old Apr 10, 2004 | 12:08 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: oh
On the ZR1, or what ever the label was for the OHC Lotus engines, they used a vac solenoid to open the High Load Butterfly, and turned on a second set of injectors, when the butterfly opened.
Staging things, makes for 3-4x the work, from what I've seen.
Why not a couple of balance tubes?.
For boosted engines the current trend is for really large plenums.
I've run 40s-55s, and 60 PPH injectors in my lil 231 CID engine just fine.
Old Apr 10, 2004 | 05:41 PM
Trux's Avatar
Transmission: t-56
rpm?
how do the larger injectors affect your idle?
I did not know that about the zr1. Thats cool.
BRoss99
Aug 10, 2025 05:08 PM
1984HO
Mar 19, 2021 11:59 AM
9192camaro
16
Feb 3, 2019 12:21 AM
onefreakz
May 14, 2018 12:15 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
