SD ecm problem?
Old Apr 8, 2004 | 11:42 PM
Kandied91z's Avatar
SD ecm problem?
i need to replace my speed density ecm? where would be the best place to pick one up and if i need to go to a yard what year and vehicle makes would run a replacement??
Old Apr 9, 2004 | 05:51 AM
CrazyHawaiian's Avatar
Car: too many ...
90-92 TPI Camaro's/Bird's. The Speed Density ECM is the 730.
Old Apr 9, 2004 | 07:33 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: SD ecm problem?
There are a buch of cars that runt he '730. Check TGO's ECM interchange page:
https://www.thirdgen.org/newdesign/t...erchange.shtml
They tend to be cheaper if you say one for a lessor car. You'll need to use the MEMCAL from your current ECM.
RBob.
Old Apr 9, 2004 | 11:52 AM
Kandied91z's Avatar
gm wants 120 for a reman...i'm kind of looking to spend less but only if i can get a quality piece.
Old Apr 11, 2004 | 06:27 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Autozone for $65.00 for a '730.
The core charge is $150.00 though!
Old Apr 25, 2004 | 11:00 PM
Kandied91z's Avatar
$10 a piece at the local yard...
Old May 2, 2004 | 01:14 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Revised numbers
I'm almost certain if you get it from GM it will be p/n 16198262.
This is the latest revision.
I'm not sure what has been upgraded, but I've heard rumors of the original boxes had problems.
If anybody knows what has been changed, I'd be interested to know as well.
Old May 2, 2004 | 01:27 PM
Kandied91z's Avatar
me too...better be alot since i'm reworking the stock piece anyhow is it worth the extra $120 gm asks?
probably not...
Old May 2, 2004 | 02:20 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Revised numbers
Nope, the 730 is about the industry standard for being reliable.
Now the 1227165, was a problem child. The early 165s just didn't have enough solder used.
The update to the 730 is just adding another Ram chip, so as to make it more usinversal in what it can replace, part number wise.
If you have an 8262, and 730 the change is obvious if you look at the Circuit Board.
Old May 2, 2004 | 09:44 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Well, sometimes (depending on the intelligence of the counter person) you can get away with quite a lot.. I went into Advance Auto Parts to buy a replacement 730 (cardone part # 77-7730 if it matters to anyone) ecm since mine took a dump right after I got the swap done (talk about confusing me after I get finished putting the motor in, it kept cutting out to limp home mode and acting all funny). I took my old ecm that came from my 1988 MPFI 2.8L V6 bird (is different size with completely different connectors) since I wasn't 100% sure that my old ecm was bad at that point and didn't want to sacrifice it as a core if it was still good. I told him that its a updated ecm design and that I already had the retrofit piggyback harness adapters for the connectors ( ). Poor kid was worried I was getting the wrong part, and I just said "It's cool, I'll take it".
Eric2ndGen
Nov 5, 2015 01:51 PM
mddaniel
Sep 8, 2015 05:16 PM
inferno15
Aug 29, 2015 01:48 AM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
