timing advance problem
Old Apr 13, 2004 | 08:02 PM
1987gt's Avatar
Car: 1989 GTA
Engine: 350 TPI (Many Mods)
i set the car at 6* but when i check it with the timing light and hit the throttle it does not advance i have it at the shop right now but i was looking for an idea on what it could be the ignition module is new cap,rotor,wires and ecm are new checked ESC its good what could it be? and im loosing alot of power how much power would i loose if the timing is not advancing with the engine?
Old Apr 14, 2004 | 08:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: timing advance problem
With the EST connector open the timing should advance once the engine RPM goes over 1,600 to 1,800 RPM. Check this with the timing light while slowly increasing the RPM. If the module is good there will be a sudden jump in timing of about 6 to 10 degrees. If this increase doesn't occur or if it occurs over 2,000 RPM then the module is bad.
Shut the engine off and reconnect the EST connector.
Start the engine and check the timing. Should be at 21 degrees BTDC (or there abouts). If the throttle is suddenly opened the timing advance should first decrease then increase as the RPMs come up.
RBob.
Old Apr 15, 2004 | 05:10 PM
1987gt's Avatar
Car: 1989 GTA
yeah i found out i have a bad calpack in the computer so the timing wasnt advancing.
Ghettobird52
Jul 5, 2024 11:18 PM
jhawkeye
May 25, 2022 06:33 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Thirim
Aug 9, 2015 06:19 PM
