Implement WB O2
Old May 2, 2004 | 01:49 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Implement WB O2
I finally got my ride up and running and am investigating using the WideBand O2 for tuning and full time running.
I'm using the 730 $8D, S_AUJP with TunerPro and have seen this code adder on the boards here (but now that I'm looking) can't find instructions.
I have also seen that the code was included with Traxions AFR program.
I'm in the configuration stages of implementing the WB and need to get some direction as to what is needed to make the conversion for full time use.
I am aware of the cost issues and want to do this right.
Old May 3, 2004 | 02:26 AM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Have you tried Mike Davis' modified bins?
http://www.eecis.udel.edu/~davis/z28/WB_hacs/
Old May 3, 2004 | 06:33 PM
JP86SS's Avatar
Thanks Dave,
I found some previously but, when you don't want something is when you find it.
I'll look at it.
dusterbd
Sep 29, 2015 08:40 AM
Krazzycowgirl
Pacific Northwest Region
Apr 15, 2009 08:51 PM
jamon8
Apr 29, 2008 11:13 PM
kevosiroc
Mid-West Region
Aug 10, 2006 06:34 PM
RWB____s
Apr 7, 2006 12:01 PM
