just painted over 180g
Car: 88 GTA "Cocaine"
Engine: 350 tpi
blocked laquer primer w/180
sprayed synthetic enamel sealer primer thinned way down
then sprayed implement paint
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: just painted over 180g
just curious,how did that turn out?I didn't think that synthetic enamels and lacquer got along with each other.
I've seen stuff that looked like it was sprayed with paint stripper.
Engine: 350 tpi
it came out good but I got more orange peal than I would have liked
after I sprayed the sealer that seperates the laquer from the enamel I will not lay down a thin layer of paint
instead I will just lay it down nice and wet after a half hour tack time between coats
I will never wetsand a car w/400 again
any more questions ask!!!
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
wow dude....wait till that thing dries out and it all sinks back into the scratches from the 180....scary....
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
well, at least it was 180 GRIT and not 180 GRAND...
Car: 84 Z28
Engine: carb 305
As long as you do your last primer filler and sealer coat without sanding you should be fine infact the paint will stick alot better. You will have alot of orange peel but after a thick base and clear and a good wetsand/buff it will look real good. 400g is the lowest I would go though just becuase i would be scared incase those scratches did show up later on especially on a dark colour base.
Engine: 350 tpi
dont do it with a urethane base
the scratches are not coming back
I bet if you painted enamel over 80 grit and put down three wet coats with a 1/2 hour flash time in between you would not see the sanding marks
you can put urethane clear over enamel
you can sand enamel within a week if you use enough hardener
wetsand the enamel w/400 and spray clear
see what you guys dont understand is that the way you are shown is not always the only way that will work
also I will never measure reduser again. I have gotten two gallons of paint that were two different viscosities
I do the drips off the paintstick method
if you use a sealer you dont have to worry about using laquer primer under your paint
Can I ask just one thing
if you havent tried it or know someone who has keep your opinions to a minimum unless they are helpful
Car: 84 Z28
Engine: carb 305
I actually just tried it the other day on my wing, but i put on one more coat of primer and didnt sand it, then I put a thick base coat on and it looked like all it might have needed was a light wetsand and buff. I did use a DA sander so I don't know what it might looked like if you blocked it or didnt use an orbital style sander. Do you have any pics of your finished paint jamon??
Car: 87 IROC Z28
well i hope it works out for you good, but i work at a body shop, a professional body shop with 50 years of experience around me and i would never ever ever think of doung sumthing like that, i block the first coat of high build primer with 220 because i done like using 180 on anything...then 320 next coat and 400 wet final coat...i think the guy would get mad if i do 180 like you on his 67 RS/SS camaro with a 6 figure resto on it.....but to each his own....i hope it dont dry up on you and look like ****
Car: 84 Z28
Engine: carb 305
I did autobody for 5 years in school and work and every body shop has different procedures anyone who knows paint knows that you dont need to sand very much becuase your paint should do the work for you.. as it dries it gets flatter. the only reason everyone does tons and tons of sanding is to just be sure that you dont see those scratches. Using a thick layer of primer filler will always be fairly flat, but you need to wetsand your base and clear. It's a waste of time sanding every layer becuase you just dont have to. Depending on the products you use I think you could get a good paint job with minimal sanding.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
ah ok grit.. i was wondering why someone would paint all that money..
Car: 1987 Trans Am
Engine: 355
Transmission: t56
what happens is the primer doesnt sink all the way into those scratches and the air thats trapped between the metal and the primer will eventually find its way out and when it does the primer will "sink" into those scratches thus revealing them thru the base and clear.
Engine: 350 tpi
ok we are talking sealer primer over the 180 in the high build primer
then use acrilic enamel as your base its way cheaper
you can spray urethane clear over enamel
here is the website that I got the ideas from
http://www.paintforcars.com/clearcoat_urethane.html
here is where I got the idea for spraying over 180
http://www.paintforcars.com/supplies_primer.html
and yes it works
just because someone does something for many years does not mean that something else could come along that makes more sense
the world is not flat anymore
and yes it works
Car: 2000 BMW M5
You've gotta be kidding. It's been known for years that lacquer primer WILL shrink back into that coarse of a sanding scratch. How bad the shrinkage looks, will depend on the grit you sanded with.
You are going 20 years back in time--------not forward. This is not "pushing the envelope" or "blowing anyone's mind" here. This is basic paint 101. Lacquer shrinks (fact). The coarser the sanding scratches, the worse the shrinkage will look over time (fact). Been there, seen it, done it. It might take a year, but it will shrink into those scratches.
2k glazes and urethanes should not shrink back into a 180 grit scratch, but lacquer most likely will.
Come on now. The guys that are disagreeing with you are correct, and they are trying to help you. Hit up www.autobody101.com for some good paint and body advice. Good bunch of guys over there, I am on the forum quite a bit.
Car: 87 IROC Z28
some people are hard on hearing around here when you try to help them...
Engine: 350 tpi
the synthetic sealer is used to stop the problem with the laquer primer
you know what? I think that I am going to stop sharing
you guys can go ahead and spend the 800 for all the supplies
pull your car next to mine, even in 10 years, and my 200 in supplies will outshine yours
heres the catch- we are both using urethane clear
whats gonna look better under your clear
A- a flat base
b- enamel
oh yeah with half the time spent as well
just the same concept as your 1000 dollar heads that wont outflow mine that I have 200 and 6 hours of porting
but with that I am done trying to release my ideas and methods because of people like you who dont even read entire threads
did you even read the links that I posted before telling me I am wrong
I am not telling you that you are wrong all I am saying is that just because you learned one way does not mean that it is the only way it can be done
there are a ton of adjustment steps that have to be learned that are not required when you spend a ton of money on name brand materials
A- a flat base
b- enamel
Engine: 350 tpi
this car was painted in implement paint 22 dollars a gallon
its a little dirty
its a little dirty
Engine: 350 tpi
I might just block him with 600
Car: 88 Trans Am
Engine: 355 c.i.
Transmission: 5 spd.
Axle/Gears: 3:42s
No.1 laquer primer way old school, yes enamel over laquer will work not the other way around though. snythetic sealer? why not a catylized sealer? And yes, after 6 months you will have shrinkage after 180 grit sand marks. Your car, do it anyway you want but why step back 20 years, except you're a tightass and won't spend the money to do it right. Might as well used rattle cans!!!!!!!!!!!!!
I guess you like the looks of a catapilar or a john deere huh?
Car: 84 Z28
Engine: carb 305
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Sep 13, 2017 12:58 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
I give it a year
