Help!!! engine wont start and check engine light does not turn on
Car: 1988 Notchback GTA
Engine: 350 L98
Transmission: 700 r4
i have a 86 trans am with the 305tpi... it started at first drove 20 feet then died and would not start.. when i started looking for problems i noticed that the when i turned the key the check engine light does no longer light.. is there a fuse for it under the hood or what could be the problem?
Please help
Please help
Car: check
Engine: check
Transmission: check
Re: Help!!! engine wont start and check engine light does not turn on
Please help
Please help
It may be up closer to the battery or in front of it. On that particular vehicle I can't absolutely say where it is.
Also check the fuse block under the dash.
RBob.
Engine: 350 L98
i checked all the colored fused.. could it be the metal silver ones?
could it be the ignition switch..the guy who i bought the car from said he installed a new one.. maybe not telling the ecm to turn on?
Car: check
Engine: check
Transmission: check
Re: i checked all the colored fused.. could it be the metal silver ones?
RBob.
