First DataMaster Log
Old May 14, 2004 | 09:14 PM
BillZ's Avatar
Car: 94 Z28, 84 Porsche 928, 84 Ferrari Mondial Cab.
Engine: LT1, 4.7L V8 Vortech/749, 3.0L V8
Transmission: A4, 5 speed, 5 speed
I've gathered my first data file with DataMaster. I'm still getting data errors, but it's much better than before, at least the data is readable now. I shortened up the serial cable as much as I could and grounded one end of the cable shield. I also eliminated a ground loop, previously I was bringing power and ground to my MAX232 board from the lighter socket and had a ground in the ALDL socket. Now I'm bringing power in through the ALDL socket and eliminated the 2nd ground wire. None of this made much difference, I was still getting MANY data errors while trying to log data. Finally, I tried using the wall outlet to power my laptop and the data errors went away. Kind of tough gathering much data this way though, I only have 100' of extension cord :-) . There was apparently electrical noise coming into my laptop through the AC inverter and the laptop's brick power supply, mucking up the data. I bought a new battery (original was completely dead, hence the AC inverter) and now most of the errors are gone.
I'm new at this data interpretation stuff, but I think I see a couple of things right away. It looks like the injectors are near maxed out. Also, I have a few anomalies in the spark advance that seem to coincide with a brief dip in the MAP. I'm not sure what's going on there. Anyone want to take a look and give some feedback? The file is at http://home.comcast.net/~p-928/928test9.uni (right click the link and save file), and is a run through the first 3 gears in my Porsche 928 Vortech/749. Any comments would be appreciated.
Old May 15, 2004 | 10:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Bill, can you convert the log into a comma separated format (CSV)? Without Datamaster we/I can't read the log file.
Thanks,
RBob.
Old May 15, 2004 | 04:37 PM
BillZ's Avatar
Hmmm, I thought DataMaster was commonly used here. I'll see about converting it to CSV. You can download DM here for free if you'd like: http://www.ttspowersystems.com/DM_Software.htm
It's actually pretty good. My data came from the xTT (Syclone, Typhoon & T-Truck) version.
Old May 15, 2004 | 07:38 PM
BillZ's Avatar
Hey, I *can* do CSV! The file can be found at http://home.comcast.net/~p-928/928test9.csv
Old May 16, 2004 | 10:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Looks PDQ. 0-60 in 4.6sec, 0-90 in 10.5 sec. Nice.
Manifold temperature sure does climb too. Graphing the RPM and MPH (Excel) is enlightening.
RBob.
Old May 16, 2004 | 11:10 AM
Brent's Avatar
I would look at:
-TPS Voltage should be 4V or more at WOT and .54V at idle
-Injector DC is too high
Cornholio7979
Sep 20, 2018 02:31 AM
L98GTA87
Oct 19, 2015 10:43 PM
89fast5oh
Sep 27, 2015 09:04 PM
BWilcox
Sep 20, 2015 12:19 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
