C950 Wiring questions....
Old Jul 13, 2004 | 10:11 PM
Stang Eater's Avatar
In the process of installing the C950 TPI kit, but can't figure out two little things, first, what is the single yellow wire coming from the distributor harness used for, and second, what is the female three wire connector(prpl/wht/grn) near the ecu used for? pretty sure I have everything else figured out, just can't find any info on these....any help is greatly appreciated.
Old Jul 30, 2004 | 07:51 AM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
call holley tech support
Old Jul 30, 2004 | 09:30 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
The single yellow wire is for the tachometer signal if using an old style mechanical advance HEI distributor, and the 950 is not controlling ignition timing.
The other connector is for a mag pickup crank trigger style ignition.
Neither one is required for our applications, unless of course, you're using that type of ignition.
On mine, I just depinned the yellow wire from connector C11 and removed it completely.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
