ECM swap
Old Jul 30, 2004 | 11:42 AM
Uwe 1985-IROC's Avatar
Car: 1985 IROC-Z28
Engine: TPI 350
Transmission: TH700-R4
ECM swap
Hallo to everybody !!!
My next mod is ECM swap ( old 870 out, new 165 in ). My question is : Can I use 2 standard europeen relays ( see pic ) or must I take the original ones ( hard to find in Germany ).
Thanks,
Uwe
Old Jul 30, 2004 | 06:40 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ECM swap
Thanks,
Uwe
You can use the locally available relays. May need to splice in different connectors and double check the current ratings. But a relay other then the GM ones will work.
RBob.
Old Jul 31, 2004 | 06:22 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: ECM swap
Thanks,
Uwe
I've used alot of Bosch relays with GM stuff.
If you're going with a non automotive series of relay you want to check the field winding resistance.
AussiePr0nCar
Mar 6, 2020 04:04 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
