Easy way to find VATS resistance value?
Old Jul 16, 2004 | 01:32 PM
87Formula4bbl's Avatar
Car: '87 Formula
Can anyone help me find the VATS resistance value in my '727 ECM (what it's looking for)? I just got my memcal in the mail today and I have it spitting the 46 code, but now I'd like to bypass the VATS so I can get that out of the way without burning a new chip for it just yet (no equipment).
According to the diagrams, B6 is the VATS signal, which runs to the CCM. Can I measure the resistance between this wire and a ground?
Any help appreciated!
-Ben
Old Jul 16, 2004 | 01:48 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, because the resistance is coded into the VATS control module and when it senses the correct resistance in the key pellet it will send a signal to the ECM. Do you have the pellet in the key and if it is a 87 car. Did you get the key, lock cylinder and VATS control module from the same donor car?
Old Jul 16, 2004 | 01:51 PM
Car: '87 Formula
No, I only got the ECM off of ebay, with the intent of just removing VATS from the code, or bypassing it, whichever was easiest. I hadn't looked too much into bypassing it until today. I see I can spend 50 bucks for the VATS module from Painless, but for that I think I may just wait till I get my burning equipment to remove it from the chip.
Old Jul 16, 2004 | 01:53 PM
Car: '87 Formula
I suppose if I wanted to do it totally right I could spend a day at the yard and get the cylinder/key/module from one of the cars. Should be pretty simple to wire in, by the looks of it, althought I dont have a diagram for the actual Control Module wiring.
Old Jul 16, 2004 | 01:58 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you can start it and run it, I wouldn't worry about it. If you are going to go to the junkyard to get the module, key & lock cylinder, don't forget the starter enable relay. I have the schematic for several of the cars with VATS.
Old Jul 16, 2004 | 02:02 PM
Car: '87 Formula
I appreciate your help, Trickster! If I decide to go that route I'll drop you a PM, if you don't mind sending the diagram(s).
Thanks!
Old Jul 16, 2004 | 02:08 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Not A problem
stalkier
Dec 6, 2015 11:25 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
stalkier
Aug 13, 2015 12:59 PM
djmarch
Aug 9, 2015 05:27 PM
