Comparing DataMaster and WB Meter values
Old Sep 3, 2004 | 06:28 AM
vettef6's Avatar
Car: 1992 LT1 Corvette
Engine: 396ci
Transmission: ZF 6 speed
Axle/Gears: 4.10
I had my tables all set using DataMaster and was pretty close +/-4% of 128BLM.
A couple of days ago I installed the WB Meter from Zeitronix and compared the AFR and BLM values.
Using the WB Meter I found I was running too rich, so I changed my VE table accordingly. My AFR at part throttle is now at about 14.2—14.7, but my DataMaser shows now that I’m way lean, about 128 — 150 BLM. I don’t know which values to trust.
I can send the DM DA and Zeitronix file to anyone that thinks he can help.
Old Sep 3, 2004 | 07:42 AM
Z69's Avatar
Z69
There was a discussion about this over on the DIY Prom board.
As long as there are no drivability issues, then the WB is correct. OR at least close. A bigger cam can throw off a stock NB. Or maybe your NB is just bad.
Also, if you're in closed loop, then the ecm is adjusting to what it thinks the NB sees as 14.7. Lots of overlap on the cam can put extra 02 in the exhaust and cause the ecm to add fuel during CL.
So I'd assume you are disabling CL to do your VE tweaks.
See the above discussion.
Old Sep 3, 2004 | 09:21 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
One other thought before you take off changing the tuning.....
Are both NB and WB sensors in the same bank of the motor?
If not, try swapping them and see what happens.
I had the same results (and still have!) and swapped the sensors and the results went the opposite direction. Which means I have either a fuel or ignition issue on the right bank of my motor (it's running much richer on that side).
So unless the 2 sensors are on the same side, don't count on a sensor problem yet.
Just my
RS Reaper
Oct 17, 2018 07:52 PM
PurelyPMD
May 5, 2016 04:57 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
