changing from a 86 MAF to a ?
Old Sep 22, 2004 | 09:01 AM
Ruiny's Avatar
Car: 86 trans am
Transmission: T 56
I have a 86 TA with the MAF
My problem is that I thought I had a leaky cold start injector so I removed it and pluged the hole.
It didn't solve the problem but the leaking injector has been fixed.
In the mean time I managed to loose the cold start pieces.
And now the car is really hard to start when cold.
So my question is can I convert my ecm to one that does not use the cold start injector?
Old Sep 22, 2004 | 12:33 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: changing from a 86 MAF to a ?
. . .So my question is can I convert my ecm to one that does not use the cold start injector?
They stopped using the cold start injector in '89. That year still uses the same ECM as your current one. However, that year also has VATS.
What can be done is to upgrade to the '89 MAF code (mask $6E) and re-burn the PROM to eliminate VATS.
Or you can change to the SD '730 ECM which was used from '90 to '92. This requires some re-pinning of the harness and again a re-burn to eliminate VATS.
RBob.
Old Sep 22, 2004 | 02:52 PM
Ruiny's Avatar
Car: 86 trans am
Transmission: T 56
This may be silly but what are VATS?
Old Sep 22, 2004 | 03:31 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Vechicle Anti Theft System (VATS) It use a resistor Plug in a key sent through some type of control Box to alow the car to know it is the correct key not some one trying to hot wire it.
The easist solution would be what RBob suggested,
Old Sep 23, 2004 | 07:55 AM
Ruiny's Avatar
Car: 86 trans am
Transmission: T 56
Thanks alot for that info
One more question.
Is this a usefull swap.
What about changing to speed denisity instead of the maf?
Logan Bryant
Aug 27, 2015 11:52 AM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 11:29 AM
Bert87
Aug 23, 2015 03:50 PM
perZ
Aug 15, 2015 01:17 PM
