EMP 10 Help
Old Oct 17, 2004 | 02:00 PM
MRCustom's Avatar
Car: '88 IROC-Z
Engine: Built ZZ4 based 350-NOS
Transmission: 700R4 2500 stall-shift kit (savin for a 6 speed)
EMP 10 Help
Ok here goes. I am having a problem burning my chips with the emp 10 programmer. I am using XP pro and Tuner Pro. I can read the factory chip into the buffer, and program from buffer(blank 27c128 chip installed) and every thing works fine. Installed in car runs fine. Now the problem, when I read to buffer, save to disk as a .bin file, open file with Tuner Pro, change something(in this case under constants, maximum spark advance, base timing)save as .bin, open programming software, load file into buffer, install blank chip, then program, I am getting a verification error (buffer at 09 device at 8E and many more if u scroll through the list).
If any one has had this problem or knows how to fix it Please let me know.
I am glad to find theDYI_EFI community and have greatly appreciated all the info and links, it was through reading and experimenting that I have reached this point.
I plan on buying cables and an emulator if I can ever get past this roadblock.
By the way when you save in Tuner Pro it asks checksum changed save yes or no, is yes the right answer?
ecm1227165 $32B ECUfile 88 TPI MAF
Old Oct 18, 2004 | 09:08 PM
MRCustom's Avatar
Car: '88 IROC-Z
Emp 10 saves origial bin. Write (blank) device to buffer,load file from disk to buffer, burn from buffer and Wallaaa. Done.
Just in case any one wanted to know, or cared.
jo88gta
Nov 23, 2009 12:59 PM
drdave88
Jun 24, 2009 06:43 PM
xtrm4xjp
Jan 23, 2009 08:52 PM
LT1Formula
Apr 13, 2003 10:14 AM
