What is the LT1 ECM casing made out of?
Old Oct 26, 2004 | 01:38 PM
David Petersen's Avatar
I am doing an LT1 swap into my 89 Camaro. I would like to have the ECM casing Ceramic coated but need to know what the casing is made out of? I thought it was cast aluminum but need to be sure. Anyone ideas?
Old Oct 26, 2004 | 01:53 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the actual case on the outside is alum.
edit:
and yea, on a show car, i have seen it polished... same with the LS1 ECM.
Old Oct 28, 2004 | 06:23 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: What is the LT1 ECM casing made out of?
If your having it coated to save it from heat, I'd suggest a new location. And those coatings will also serve to keep it hotter.
YMMV
Old Oct 28, 2004 | 09:35 AM
I was going to coat it for looks and I heard that that was the best thing to do as far as heat was concerned. ie better than powdercoating etc. It won't be maintinece free but I think I will just have it polished. It is going in a great location on the drivers side right above where the wiring goes into the car. Thanks for the input.
Old Oct 28, 2004 | 02:34 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Keep in mind that the heat is generated by the electronics inside, so any thermal barrier coating is just going to hold more heat in.
For show cars, I've seen them painted, polished, powdercoated, and even chromed.
Most of mine are just oxidized
Old Oct 28, 2004 | 03:20 PM
Well now that makes sense. I misunderstood ceramic coating. I was under the impression that it was a good heat conductor. It should have clued me in that as they use it on headers it would heat in.
1984HO
Mar 19, 2021 11:59 AM
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
Cornholio7979
Sep 20, 2018 02:31 AM
sreZ28
Aug 14, 2015 07:48 PM
