How to pull codes ...85 Grand National?
Old Dec 22, 2004 | 12:33 PM
RPO-B4Z's Avatar
Car: 1989 IROC-Z 72Kmi.
Axle/Gears: 2.77 aussie 9 bolt
Is it the same as my 89 Iroc-Z?? My friend has an 85 GN and says the check engine light is on (he hasn't had it long). Do you just jump the terminals on the ALDL connector like I do on my Iroc?
Old Dec 22, 2004 | 01:05 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
I believe all of those connectors are the same for GM vehicles. I would suggest checking a reapir manual, or buying a code reader. They're quite cheap, and should work with any GM obd1 system. Oh yeah, and this thread'll be locked because it's not thirdgen. Try a GN forum..
Old Dec 23, 2004 | 09:47 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: How to pull codes ...85 Grand National?
Yes, short A->B. Then read the flashes.
Some good sites:
http://www.turbobuick.com/messagebd/
Be sure to stop by the library at this one
http://www.t6p.com/forums/index.php?
Old Dec 23, 2004 | 10:18 AM
1quikformula's Avatar
Car: 1991 Pontiac Formula
Engine: 350 C.I
Transmission: 700R-4
You may also want to try this place http://www.gnttype.org/maint/malf.html
Old Dec 24, 2004 | 10:48 AM
Reds ttype's Avatar
Car: Turbo Buick
Engine: whistling V6
Transmission: lots of broken ones
Re: Re: How to pull codes ...85 Grand National?
Some good sites:
hey Grump you forgot one
www.turbobuicks.com
chazman
Aug 28, 2018 03:25 PM
2012sergen11
Nov 23, 2015 09:46 PM
kymmee
Sep 2, 2015 09:01 PM
86IROC112
Aug 31, 2015 07:00 AM
chazman
Aug 22, 2015 02:01 PM
