746 wire colors
Car: 2001 SS Camaro
Axle/Gears: I should know this
746 wire colors
I've been searching around and I can't find a pinout with the colors.
I'm about to repin my 746 to 730 and i'd like to know what the colors of the wires should be on the 746 and 730.
I'd appriciate it if someone could post this information for me.
Thanks,
Thanks,
Car: check
Engine: check
Transmission: check
This thread can get you started:
https://www.thirdgen.org/techbb2/sho...hreadid=216453
For the harness colors go over to the diy-efi.org site , gmecm, and under ECMs there are wiring diagrams.
RBob.
RBob.
Car: 2001 SS Camaro
Your a good man, thanks.
Think i bumped into something here. I believe this is what I am looking for.
'92 F body 5.0 and 5.7: Page 1, Page 2, Page 3, Page 4, Page 5, Page 6, Page 7
On page http://diy-efi.org/gmecm/ecm_info/1227730/
Now that I can see the differences between the 2 ecms. My goal is to make my wiring look like the 730's wiring diagram.
Am I correct in my theory? It seems much easier to understand than this site https://www.thirdgen.org/techbb2/sho...readid=216453. Unless I am totally missing somthing.
Car: check
Engine: check
Transmission: check
Yes, just need to change the wires to the new position in the connector. MAT is still MAT, may just go to a different pin (and so on with the remaining).
There is a '747 wiring layout there too. That is close to the '8746 but not exact.
RBob.
RBob.
Linson
Aug 21, 2015 02:12 PM
LT1Formula
Aug 20, 2015 09:36 PM
