limitations of stock computer?
Old Dec 26, 2004 | 07:24 PM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
engine is an 010 block with forged crank, rods, pistons, file fit nitrous rings, compression ratio is 10:1, has a mechanical roller camshaft..comp XR280 R-10, lift is .578/584, duration at .050 is 242/248 with a 110 lsa, and AFR 195 competition heads...i would plan on using a mini ram if i could use the stock computer...would only be taking it to 7000 rpm...with a victor jr, 1" spacer and 850 carb it dynoed at 522hp@6600, 454Ibs of torque@5200..engine only produced 9" of vacuum at 950rpm...would this be pushing the limits of the stock computer?
Old Dec 27, 2004 | 05:27 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: limitations of stock computer?
The stock ecm can be set up to be *numb* enough to run about any engine. But, it gets challenging. The newer aftermarkets are approaching the sophistication of the oems, cause you need a certain of complexity to manage an engine.
I'd look at the new Holley Manifold, the Mini Rams, have an inherit shortcoming.
Old Dec 27, 2004 | 07:45 PM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
what do you mean by a shortcoming?...i already have the converted lt1 intake which is why i was going to go with it...i would retain the carb setup but don't want to, think it would be a cooler setup efi...engine is coming out of a pro street nova to make room for a big block and i could de-cam it a little possibly go hydraulic...not sure what exactly i want to do yet...
Old Dec 31, 2004 | 06:41 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The rear wall of the manifold forms the rear wall of the runners, forcing the rear cylinders to run lean. As you dial the HP level up, it becomes more and more of an issue. There's been plenty of posts about it.
I've seen a LT1 manifold that had the top cut out, and redesigned so as to increase the plenum volume that worked really nice.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Bryan F
Aug 18, 2015 02:28 PM
Thirim
Aug 9, 2015 06:19 PM
