727 ECM run a TBI
727 ECM run a TBI
Can the Corvette 727 ECM run a TBI setup? I would have to re-pin the harness for the different plugs, but the sensors and function are almost the same. Any ideas?
Car: An Ol Buick
Engine: Vsick
Re: 727 ECM run a TBI
Car: check
Engine: check
Transmission: check
The '727 ECM will run a single TBI injector, that's it. So unless you have a 4-cylinder Iron Duke in your 3rd gen that you want to convert to a 1bbl TBI, won't work.
RBob.
RBob.
What I am doing is running the GM 2.8 V6 in dune buggies instead of the aircooled VW engines. Even bone stock they are twice as powerfull and 4 times more reliable. You can get em used out of Citations and Celebrities for $150.00 a pop. The TBI is simple and reilable as well, but I have had problems keeping the ECM functioning in an open chassis. The 727 would have been perfect, but oh well. It seems like what ever enclosure I built is too tight and can't breath(burns up), or breathes too good and condinsation gets it. Any ideas?
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Just had another thought. Will the 727 run the MPFI like on the 3.1 V6 that came in some 3rd gens?
92camaroJoe
Aug 13, 2015 06:07 AM
