Need quick answer on IAC question
Old Mar 7, 2005 | 02:18 AM
87Formula4bbl's Avatar
Car: '87 Formula
Ok, heres the rundown. I just got this new setup running, pretty tickled. I start it up and, after getting the timing in the neighborhood, its idling at around 2000. It's running way rich (blms at 108 pretty quickly) and may need some timing into the chip (header collectors glowing bright orange). What I need to do is get the idle down to normal. After logging about a minute's worth of data, I scroll through and see that as soon as the engine fires, the IAC goes from 160 steps down to zero in a matter of maybe a second or two while the rpms go from 900 to 1900 in the same time period. Desired idle speed is 662rpm. My question is, did I wire in the IAC backwards? Looking at the IAC schematics, it seems that if you had every pin (A B C D) wired in reverse it would spin the IAC pintle backwards. So, by setting the IAC at 160 steps initially (computer default for start-up) which should be fully opened, it's probly fully closed, and by trying to bring the idle down it instead brings it up but has no way of dealing with it otherwise. Can someone verify my assumptions, I have limited time to piddle when I make it home to work on the car on weekends, I'm just trying to maximize my efficiency at fixing bugs.
TIA
Ben
edit: I emailed someone on this board that builds harnesses for the RamJet and he pretty much verified that I do have them backwards. Problem solved.
Old Mar 7, 2005 | 05:01 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
there are 2 coils inside of the IAC, and switching the wires on one of them will reverse the direction of travel. Swapping A and B should be good enough if you want to try that theory.
You may have a stuck open throttle. You may have a huge air leak (runners on the wrong sides). Maybe a dead IAC, or stuck IAC, with the extra fuel bogging it at first, and closed loop leaning it back to normal causing the idle to rise.
Do you have to depress the pedal to get it to start? I think you may be right on this one, though. I've seen many IAC diagrams that have the pins in different orders, so I can imagine it being backwards easily.
Old Mar 7, 2005 | 12:03 PM
Car: '87 Formula
Well, its a brand new setup. New everything, IAC, etc. So I don't think anything is stuck. I think the wires are probably backwards. Just looking at the datalog, it seems that it is doing exactly the opposite of what it's supposed to. Having two coils, it seems that it would send current through either one for stepping the pintle in and the other to step it out, does that sound right. So ya, sending current through the opposite coils it was intended to, it would work in reverse. Just trying to think this through in my mind, does it sound right? Heres a snippet of the log:
Code:
TPS   RPM    MAP    Runtime  Target A/F  INT  BLM  Cell  BPW  Desired RPM IAC Steps SA(TDC)
0.57  0      80.39     0        14.73    125  108   4    0.5      3187       160      84.38
0.57  0      70.59     0        13.24    125  108   4    0.5      3187       160      83.67
0.57  900    60.39     0        13.57    128  118   4    0.21     662        152      89.3
0.57  950    56.86     0        13.6     128  118   4    0.24     662        136      89.3
0.57  1075   53.73     0        13.6     128  118   4    0.26     662        120      89.3
0.57  1200   49.8      0        13.8     128  118   4    0.27     662        103      89.3
0.57  1325   46.67     0        13.91    128  118   4    0.28     662         88      89.3
0.57  1425   43.14     0        14       128  118   4    0.3      662         84      89.3
0.57  1500   40.39     1        14.06    128  118   4    0.33     662         84      84.02
0.57  1575   38.43     1        14.12    128  118   4    0.34     662         82      84.02
0.57  1625   36.47     1        14.19    128  118   4    0.36     662         80      84.02
0.57  1675   35.29     1        14.28    128  118   4    0.37     662         79      84.02
0.57  1725   34.12     1        14.34    128  118   4    0.39     662         78      84.02
0.57  1725   33.73     1        14.4     128  118   4    0.39     662         77      84.02
0.57  1775   32.94     1        14.44    128  118   4    0.4      662         73      84.02
0.57  1750   32.94     1        14.44    128  118   4    0.4      662         68      84.02
0.57  1775   32.55     1        14.44    128  118   4    0.41     662         61      84.02
0.57  1775   32.94     1        14.44    128  118   4    0.41     662         49      84.02
0.57  1775   32.94     2        14.44    128  118   4    0.4      662         37      84.02
0.57  1800   32.94     2        14.44    128  118   4    0.4      662         25      84.02
0.57  1800   33.33     2        14.44    128  118   4    0.4      662         13      84.02
0.57  1825   32.94     2        14.44    128  118   4    0.4      662          2      84.02
0.57  1825   32.94     2        14.44    128  118   4    0.4      662          0      84.02
0.57  1825   32.55     2        14.44    128  118   4    0.41     662          0      84.02
Old Mar 7, 2005 | 12:16 PM
Car: '87 Formula
Sorry for the messy table, I tried reformatting it but doesnt seem like it helped any.
Old Mar 7, 2005 | 02:35 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The CODE tags fix tables right up. The IAC is a bi-polar stepper motor. Just reverse the two wires on the same coil and it'll work (as RednGold86Z mentioned).
A coil can be found by measuring the resistance between the pins. A coil will measure about 40 ohms. Just two coils and only need to swap the wires on one.
RBob.
Old Mar 7, 2005 | 02:44 PM
Car: '87 Formula
Worked like a charm. Thank you!
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
bamaboy0323
Aug 15, 2015 07:20 AM
