Problem with C950Pro
Old Mar 17, 2005 | 06:07 PM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
Posted: Thu Mar 17, 2005 7:04 pm Post subject: Problem need help
Ran at the strip with my car did crappy 10.3 in the 1/8. some of it was my mistake 1.1 RT. but heres the problem turn the car off had a hail storm. dime size hail and then tried to start the car it started ok but when rev'd up to 1200 thru about 2000 it spits and sputters. sent the car to my engine builder and he ran the car and the headers got CHERRY red. The programming was set back to an old program that worked before. I have the C950 pro system. please help. Need help ASAP
Chevy SBC 350 block (383 internal balanced)
Holley Stealthram w/30lb injectors
Eagle 383 balanced rotating assemble w/SRP pistons
and 6.0 rods
Comp Cam Custom grind cam changed Lobe sep. from 110 to 112
Lift .502 .510
Duration @ .050 224 230
108 Center line
Comp cam springs and push rods
Comp Cam pro magnum roller rockers
Alumnium Heads 64CC angle plugs
Old Mar 21, 2005 | 12:16 PM
D F's Avatar
D F
Go to modifiers and look at the coolant vs timing temp. SHould be 0.
Old Mar 21, 2005 | 02:59 PM
Car: 1992 Camaro RS
thanks that was the major part of the problem at least i can drive now. For some reason it was set at -32?? all the way across. now it missing but i have a bad collector so i'm going to fix that and the burnt plug and that should fix that. thanks for the help.
Old Mar 21, 2005 | 09:09 PM
Car: 1992 Camaro RS
fixed it. it was a programming issue. went back to a really old program and started from scratch work awesome now. thanks for the input.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
