ecm logic flow
Old Apr 2, 2005 | 02:18 AM
inuyasha_lost's Avatar
Car: 92 Camaro RS 25th Anniv
Engine: 93 LT1 w/Vette Access
Axle/Gears: 97 T/A w/3.42 posi
ecm logic flow
hey gang, my fuel pump control circuit went dead. the ecm is not sending the voltage to the relay. i need to know the logic flow for the ecm. i need to know what tells the ecm to turn voltage on to the relay. thanks
Old Apr 2, 2005 | 07:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
At key-on, engine-off the ECM enables the FP relay for 2 seconds. Then at crank or run time the ECM enables the FP relay whenever dristributor reference pulses (DRP's) are present. Two seconds after the last DRP the ECM will disable the FP relay (such as when the engine stalls).
There is also an oil pressure bypass switch that enables the fuel pump whenever oil pressure is above ca 4 psi. This switch doesn't use the relay, it powers the pump directly.
RBob.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
customblackbird
Oct 1, 2015 04:30 PM
BWilcox
Sep 20, 2015 12:19 PM
anesthes
Sep 18, 2015 12:34 PM
david068513
Sep 18, 2015 10:36 AM
