CNP coil pinout?
Car: 91 Red Sled
CNP coil pinout?
So I've got a few CNP's sitting here on my desk from a friend. They're the truck style with the little aluminum fin heat sink. What exactly are the pins? I assume power, ground but there are 2 others, 1 is the signal but a 4th? I have some background as too how they fire but I'd like to check them all out with a simple 555 circuit
. Moderator
Car: check
Engine: check
Transmission: check
I don't know which pin is which, however, the pins will be: +12V igniton switched, power ground (to block), trigger signal (from ECM), and trigger ground (from ECM).
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Originally posted by JPrevost
How can I tell which pin is which?
RBob.
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
I happen to have a set of truck coils with the factory wiring still attached.
If you orient the coil so that you are looking into the 4-wire receptacle, with the coil oriented so that the heat sink fins are beneath the connector, pin A will be on the left, and pin D will be on the right.
Pin A = chassis(?) ground (black)
Pin B = ref(?) ground (brown)
Pin C = trigger (color varies by cylinder)
Pin D = 12V power (pink)
What I can't tell for sure from the coil harness is which is the chassis ground, and which is the trigger ground. From the wire color, I would expect that the black wire (pin A) is the chassis ground, but I can't be 100% certain.
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
