Funky VSS Q's
Old Apr 17, 2005 | 12:49 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Funky VSS Q's
How do mechanical speedo birds and maro's tell the ecm they're moving? What kind of sensor converts the cable speed to something ecm can understand? Pictures?
Old Apr 18, 2005 | 07:03 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Mounted on the back of the speedometer is an infrared LED and an photo-transistor (in a small black plastic housing). This picks up the reflection from a small bar spinning inside of the speedometer and sends the signal to a small buffer box. This box has two outputs, one for the ECM and the other for the cruise control (which may or may not get used).
The small box is typically lime green and is mounted on/in the cluster.
RBob.
Old Apr 20, 2005 | 12:49 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Or yellow.
Old Apr 20, 2005 | 03:42 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Thanks a lot. That helps a ton.
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
