code 34
Old Apr 21, 2005 | 05:23 AM
yupitsme's Avatar
Car: '88 gta
Engine: 5.7 ltre 350
code 34
a quick question,can a faulty injector bring up a code 34 .i know the code 34 is for the mas air flow sensor but i know it is not it,I've changed the idle air control,cleaned up the air intake,n anything to do with fuel delivery.besides the engine sounds like there is a injector fouled up, just want to check with u guys first
thx
Old Apr 22, 2005 | 11:51 AM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
Disconect the wiring harness from the MAF sensor. If the idle smooths out your MAF sensor is defective. I f the idle stays ruff smething else is wrong. Could be an inj.
Old Apr 22, 2005 | 05:33 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: code 34
thx
As well as a burnt intake valve.
Mechanical ills, can trigger codes being set.
Old Apr 23, 2005 | 09:21 PM
yupitsme's Avatar
Car: '88 gta
i 've been figuring it would be mechanical,i will be replacing all the injectors anyways n see what will happen. thx
Old Apr 25, 2005 | 11:40 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
If I haven't followed the stock troubleshooting flow chart for code 34 ( Code 34 chart ) I wouldn't say for sure what it is or isn't.
I *knew* my MAF was good before I installed it, code 33 came up after install, surprise, flow chart said my MAF was bad, and the flowchart was right.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
