305 computer starving 350!
Car: 1989 Pontiac Trans Am GTA
Engine: 357 Tuned Port Injection
Transmission: Borg Warner T-5
Axle/Gears: BW 3.45 9-Bolt
I've searched and could really find any answers to my question. First of all, I've swapped from a 305 to a 350. Has a t-5 and the 305 computer. The problem is that the motor doesn't really pull past 4 grand. Considering a 350 will pull in as much air at about 4000 as a 305 will at say 6000, does the computer not have enough of a fuel delivery table to respond to anything over 4000rpms? It just flat dies at 4000. Thanks for your help.
Scott
Scott
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
You need to buy a 350 memcal(chip) and install it in your computer. You should be able to get it at any GM dealer. As for the stuff you didn't talk about. You need a 350 knock sensor and 22lb/hr injectors instead of the 19's that came stock on your 305. If the motor is not stock then you better look at moates website an do some learning and ordering.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: 305 computer starving 350!
Originally posted by Super_GTA.Considering a 350 will pull in as much air at about 4000 as a 305 will at say 6000, does the computer not have enough of a fuel delivery table to respond to anything over 4000rpms? It just flat dies at 4000.
Listen to what they told you above, as you need to upgrade you're injectors and chip (well, not so much you're chip if you're running MAF, just bump up you're fuel pressure with the replacement injectors)... but remember, even with you're 350 running right, don't expect it to pull all the way to 6000RPM. It'd be like Michael Johnson running down the track as fast as he could, while breathing through a straw.
HSR
Flatlining
I figured it might be the computer because the car basically flatlines at 4000 rpms. By flatlines, I mean I can run faster if I shift at 4000. I have some ported 081 heads that will be going on shortly. I'm hoping these will help. Does the intake really hinder performance that much?
Re: Flatlining
Originally posted by Super_GTA.I have some ported 081 heads that will be going on shortly. I'm hoping these will help.
Originally posted by Super_GTA.Does the intake really hinder performance that much?
92camaroJoe
Aug 13, 2015 06:07 AM
