Loose PCM? ECM Removal Question
Old Jun 5, 2005 | 08:18 PM
orangetang's Avatar
Car: 91 Firebird Green
Engine: SBC L03 - TBI 5.0L V8
Transmission: WC T5
Someone mentioned I should check and see if the PCM card in my ECM has come loose... I can't find my service manual, but I did find the ECM housing under the passenger side dash. Is there a trick to sliding this out, and is there any precautions I might want to take?
Old Jun 6, 2005 | 07:50 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I think some one may be pulling your leg. Your ECM doesn't use a PCM card, and it doesn't have a slot for one.
As for getting the ECM out, not quite sure on that year/ECM, it may be easiest to remove the two screws from the lower area of the dash. Then drop it down mount and ECM together.
RBob.
specialized
Jun 18, 2022 09:26 AM
NBrehm
Aug 25, 2015 11:49 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
