ECM Swapping, whats the best?
Old Jun 18, 2005 | 09:29 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I always see adds for certian ecm's. Some are better than others?
Is there a reason to get different ones?
My car is an 88 MAF L98. Is there a different ECM I should be looking for?
Whats the benifit?
Old Jun 22, 2005 | 07:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Sometimes people will change their systems from MAF to SD. This entails an ECM change. A swap from TBI to TPI will entail an ECM change. The 2.8l engines used a rather restrictive MAF ECM that can be changed to the TPI '165 ECM.
Your setup uses the '165 ECM. If you wanted to go SD and get rid of the MAF then a swap to the '730 ECM is in order. Although there is Aussie code available for the '165 to run SD.
Folks that go boosted change the ECM and code to one that handles the wastegate and boost fueling and timing.
Just a whole bunch of reasons for changing and for not changing. It really depends upon what is currently in the vehicle and what direction the engine is going.
Oh, that brings up another ECM swap: an E transmission. There are ECMs (PCM actually) that will control an electronically shifted auto trans. So if going to a 4L80E trans (a TH400 with overdrive and electronic control) having a PCM that handles the trans and engine is a great swap.
RBob.
AussiePr0nCar
Mar 6, 2020 04:04 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
