engine wont start after FAST upgrade
Old Jun 24, 2005 | 07:17 PM
BOTTLEDZ28's Avatar
Transmission: A4
I swapped out my SD setup for a FAST setup and now I cannot get the engine to fire. All it does is rotate. I have a laptop hooked up to the ECM and I am able to connect to the ECM. I am getting readings from various sensors and the fuel pump is working correctly. I do have a VATS setup in the car and I have tried jumping the 2 biggest wires on the starter enable relay but nothing changed. if anyone is familiar with the dashboard layout for the laptop then please chime in and let me know what I can look for to help figure out what if wrong here. Its gotta be spark or VATS I think. You guys have any tips for me here. Im am pulling my hair out.
Old Jun 25, 2005 | 07:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The FAST setup doesn't care about VATs, so it isn't that. Pull a plug and see if its wet with fuel. Then check for spark. Power to coil?
RBob.
Old Jun 25, 2005 | 05:38 PM
BOTTLEDZ28's Avatar
Transmission: A4
Found it, Dizzy was 180 off.
Frozer!!!
Jan 19, 2024 04:55 PM
Fast355
Dec 2, 2016 06:33 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
