Which TPS wire
Old Jun 29, 2005 | 10:54 PM
brutalform's Avatar
Which TPS wire
Which TPS wire, A,B,or C would I splice into to send a .5v signal to my Innovate WBO2 RPM converter? I need this in order to log with the WB. I would like to create a 3D graph with RPM, TPS%, and AFR. Thanks.
Old Jun 30, 2005 | 12:16 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i know its nopt the black wire, its ground. so its one of the two. use a multimeter to find out.
Old Jun 30, 2005 | 12:56 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Do you need a constant .5V? If so, TPS won't help you...but on my '89 the dark blue wire is the signal voltage to the ECM...i/e appx .54 at idle to 5V at WOT, and the grey wire is the refernce 5v line...Traviz got the ground as black.
HTH
Old Jun 30, 2005 | 12:17 PM
brutalform's Avatar
Thanks to you both! I'll have to find my Howell manual. I'm sure its in there, or perhaps the Helms.
Old Jul 1, 2005 | 02:09 PM
EdgesZ28's Avatar
Car: 91 GTA - 94 TPI Suburban
According to Chilton's and www.chevythunder.com, for the 730 ECM the signal inputs that you may want to use are:
1. TPS - Dark Blue
2. MAP - Light Green
http://www.chevythunder.com/199092_f...227730_ecm.htm
I would think the MAP is vital to determine load, since you can calibrate the LM-1 to display kPa from the reference 0-5v.
Good luck, Ed
Old Jul 1, 2005 | 05:50 PM
brutalform's Avatar
Thanks for your reply, Ed. Yes, I'm really starting to get used to the LM-1, and its logworks. I did a few logs, (not real time) and I was just using the RPM input, along with the AFR. Now its time to create a 3D graph. Eventually, as I learn more, I'll try to use the LM-1 to its full ability. I just wanted to be sure as to not damage the meter. Man, from what I see so far, this is a "quality" tuning tool.
Old Jul 5, 2005 | 04:41 PM
Ronny's Avatar
my old stock harness had diff color wires than my new tps but i was able to spice it in (tps sensor and feed to LM1)with no trouble. i dont think any damage can occur. none did in my case. i am reading A/F and tps and rpm BUT as was stated the MAP is a valuable feed to LM1. will be adding that as soon as paint dries.
Old Jul 5, 2005 | 06:41 PM
brutalform's Avatar
Thanks Ronny, Yea, it says as long its no more than 5v, it should be alright.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mdtoren
Aug 23, 2015 12:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
mdtoren
Aug 16, 2015 05:45 PM
