Help! Can't Find ALDL Connector!
Old Jul 26, 2005 | 08:14 PM
1FSTZ28's Avatar
Car: 1989 Camaro IROC Z28
Engine: 350 Stealth Rammed
For some reason I/we cannot find the ALDL connector in my Camaro. It is not hanging down under the dash. I have a 1989 IROC Z28. If anyone could help me i would really appreciate it! Thank in advance!
Old Jul 28, 2005 | 09:16 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
GM originally put a snap-on rectangular plastic cover over the ALDL connector when these cars were new. By now, they're long since gone on most cars, but perhaps yours still has one. Look for a black rectangular piece of plastic about 1"x3" -- if you find one, pry it off, and you'll find the ALDL connector.
Otherwise, perhaps the mounting screws were removed at some point, and it was simply tucked up under the dash?
Old Jul 29, 2005 | 12:15 AM
1FSTZ28's Avatar
Ok, Thanks. Ill check it out tommorrow and see if i can't find anything.
Old Jul 29, 2005 | 06:36 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It may also be hidden up next to the fuse box. Real hard to see there. Just to the right of the fuse box which is under the dash on the far left of the interior.
RBob.
Old Jul 30, 2005 | 01:33 AM
1FSTZ28's Avatar
I found it! The previous owner had tucked it behind the cd player. Now to get my check engine light problem checked out.
eightsixseven
Dec 16, 2024 01:50 PM
GTAman
Mar 15, 2019 11:40 AM
TheJoeY88
Dec 31, 2016 07:30 PM
Thornburg
Aug 27, 2015 11:34 PM
