new scanner that wont read my iroc
Old Aug 3, 2005 | 12:47 AM
emayetete's Avatar
Car: 1988 iroc
Engine: '91 350
Transmission: 700r4 w/ b&m shift kit
so i bought this 460$ scanner hoping i could run a diagnostic on my car. after a little bit of research i found the port to plug it into and tried to run a scan. it says that my car is not responding. i ran it several times doing everything to trouble shoot the scanner according to the manual. i have a 88 iroc with a 91 5.7 in it. i tried both years to configure the scanner and nothing works. i have a autoxray 5000. can anyone help me?
Old Aug 3, 2005 | 11:36 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
i had the same problem with a friends iroc my scanner would not read found it to be his ecm was bad but the car ran fine.
Old Aug 4, 2005 | 12:45 AM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
tpi motors have a lip mode wich allowes them to run. This was because the tpi was origanly designed to be for marine use--at least that is what iI heard make sence high tork at a low rpm
late
r
and
GB
rick
Old Aug 4, 2005 | 03:35 AM
emayetete's Avatar
Car: 1988 iroc
Engine: '91 350
right this all makes sense, now how do i fix my scanner error?
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Thornburg
Aug 25, 2015 01:46 AM
Electro_X
Aug 19, 2015 07:59 AM
mizz0313
Aug 12, 2015 06:45 AM
mustangman65_79
Aug 11, 2015 03:17 PM
