Wiring harness question
Old Sep 7, 2005 | 10:03 PM
87camaroz28310's Avatar
Car: 87 plane jane with gfx
Engine: 350 worked vortec head .515 .515 cam and 1.6 rockers and shorties for now til i can afford the supercomps
Transmission: super t-10 or t-5
Axle/Gears: auburn with 3.42 stock axles
Is an 85 wiring harness different than a 86-89 wiring, if so whats the major difference, and will it work for an engine swap
Old Sep 9, 2005 | 03:05 AM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
'85 is somewhat different. Main differences were a lack of the MAF power and burnoff relays, and it used a different ECM.
You can use the '85 harness, but it will require some changes.
Luckily for you, Mike Davis documented the procedure for updating an '85 harness to work with the '165 ECM.
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
