DIY-WBO2 Final Assembly & Testing???
Old Jan 6, 2006 | 08:43 PM
87tpi7749's Avatar
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
Hey all, My DIY-WB is done, sensor in hand. I wanted to test circuitry and calibrate unit, but it took so long to build, the DIY site crashed and I never printed the test literature. I have tried to find any info but I haven't found what I need to test & calibrate. A web site or email would help out if someone knows where this info is hiding. Thanks!
Old Jan 7, 2006 | 07:50 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
PM sent.
For calibration the resistor is contained within the sensor connector. The wires from that resistor go to two locations on the PCB. J9 and J10, labeled CalR
The device at D5 needs a .01uf to .1uf capacitor added between pins 1 & 3 (outer two pins). Darn near any 'ole ceramic disk, or mono cap will work.
The big resistor R4, needs to be paralleled with 10 to 15 ohm 1/4W resistors until the sensor warms up in 35-40 seconds. Usually takes 3 or 4 of them.
RBob.
Old Jan 9, 2006 | 06:44 AM
Cherry84's Avatar
Car: 84 Corvette Turbo
Engine: 5.7
Transmission: modified 700r4
DIY WBO2
How much 4 one ????
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
